Hi David,
Autodesk MapGuide Release 6 does not officially support Microsoft Internet
Explorer 6.0. Due to the proximity of release dates for Autodesk MapGuide 6
and Microsoft Internet Explorer 6, testing of the various MapGuide clients
in this environments did not occur.
You will need to uninstall Internet Explorer 6.0, re-install the Autodesk
MapGuide 6.0 Viewer, and then re-install Microsoft Internet Explorer 6.0.
Go to Start menu, and select Settings>Control Panel. Select the Add/Remove
Programs icon, and click the Change/Remove button for Microsoft Internet
Explorer 6. Select the "Restore the previous Windows configuration" radio
button, and click OK. This will restore Internet Explorer to version 5.x.
Install the Autodesk MapGuide 6. 0 Viewer.
Install Microsoft Internet Explorer 6.0.
Fletcher Clover
GIS Product Support Analyst
"David Gannon" wrote in message
news:26D6245926F2B858D849689A349E71FD@in.WebX.maYIadrTaRb...
> Is there any issues with MG6 Viewer and IE6? The install fails and the
> prompt says I need IE 5.X or higher. After changing the registry to have
a
> version of 5.X it works (then I change back to 6.X).
> David G
