Initial Map display on ipad iphone very small and does not follow initial display sale size as set in Mapguide Studio.
More importantly as zooming into map, at a partiular scale everytime all layers turn off. All layers are set in studio to remain on at all scales. Map initial display is set to within extents. Is there something I need to modify in html filr or related.
Thanks ahead of time
Gordon
I have played with the extents in studio 2013 but it does not seem to make any difference. I get Parse errors or the map displays way out and zooming in causes all layers to turn off. Different maps may not load at all , just spin indefinitely. One map is down to a single parcel layer. No dice. By the way I still have the Cold Fusion T shirt from the Autodesk training in Virginia around 1998 MapGuide 6.0 from the class you taught
I can use MobileViewer in MapServer 2014 if my map is based on data that is in Lat Long. If I try to view a map based on data that is in the British National Grid projection I experience exactly the same issues i.e. layers all turn off when I zoom in.
Has there been any progress in solving this problem?
Try adding the &baselayers=osm to the end to see the data (in a weird location) but at least your will see your data.
