Infrastructure Map Server General Discussion
0 Kudos
Post 1 of 8
Map Display issue Using MobileViewer
670 Views, 7 Replies
10-12-2012 07:02 PM
Initial Map display on ipad iphone very small and does not follow initial display sale size as set in Mapguide Studio.
   More importantly as zooming into map, at a partiular scale everytime all layers turn off. All layers are set in studio to remain on at all scales. Map initial display is set to within extents. Is there something I need to modify in html filr or related.
Thanks ahead of time
Valued Mentor
74 Kudos
Post 2 of 8
Re: Map Display issue Using MobileViewer
10-17-2012 04:05 AM in reply to: cpietra
the map extents are very important to all layouts and the mobile viewer.
i would recommend downloading the latest Maestro and using the tool to collect the extents from all layers in the current map. to find it, just open your map.
i wish this tool was in studio.
0 Kudos
Post 3 of 8
10-17-2012 04:11 AM in reply to: cpietra
Gordon
I have played with the extents in studio 2013 but it does not seem to make any difference.  I get Parse errors or the map displays way out and zooming in causes all layers to turn off.  Different maps may not load at all , just spin indefinitely.  One map is down to a single parcel layer. No dice.  By the way I still have the Cold Fusion T shirt from the Autodesk training in Virginia around 1998 MapGuide 6.0 from the class you taught
Valued Mentor
74 Kudos
Post 4 of 8
10-17-2012 04:15 AM in reply to: cpietra
ah, remember that class. love cold fusion still.
i had trouble adding any map not in spherical mercator. are your maps in that?
0 Kudos
Post 5 of 8
10-17-2012 04:35 AM in reply to: cpietra
No   State Plane NAD 83 NY Central    Do you have a link to current Maestro ?
Valued Mentor
74 Kudos
Post 6 of 8
10-17-2012 04:40 AM in reply to: cpietra
i would try spherical mercator (google projection) first.
maestro
http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
1 Kudo
Post 7 of 8
11-13-2013 03:44 AM in reply to: gluckett
I can use MobileViewer in MapServer 2014 if my map is based on data that is in Lat Long.  If I try to view a map based on data that is in the British National Grid projection I experience exactly the same issues i.e. layers all turn off when I zoom in.
Has there been any progress in solving this problem?
Valued Mentor
74 Kudos
Post 8 of 8
11-14-2013 08:36 AM in reply to: cpietra
Try adding the &baselayers=osm to the end to see the data (in a weird location) but at least your will see your data.
