I utilized The EPLOT code to output a Mapguide AJAX map out to DWF using mappingService.GeneratePlot and When I am able to mark the map up in Design Review but unfortunately measure is useless as well as roundtriping back into a DWG is useless NEITHER WORK...it obviously does not send out georeferenced information as does map when you Plot...Another Oddball occurunce it will publish data on only the topmost layer to have data attributes and no others...Man This is SO CLOSE TO PERFECT FOR ROUND TRIPPING DATA...PLease Someone Fix This...I have Customers Who desperately hold their collective breaths for such a solution for once
