I do not know of any routing applications specifically for Autodesk Map or
MapGuide. If you do end up building one, you may want to consider making it
flexible enough to work with any FDO datasource and then you can release
your routing engine either commercially or as part of the Open Source
Geospatial Foundation. You may want to take a look at this:
https://fdo.osgeo.org/
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
wrote in message news:5342078@discussion.autodesk.com...
We want too adopt GIS, GPS, AVL (automatic vehicle location) and related
technology. The main requirements are:
It should work under Map 3D 2007, Topology must be stored in MS SQL.
Ideally, the system should be developed on the Microsoft .NET platform with
SQL Server 2005 as a back-end DBMS.
Currently we are having a hard time figuring out how to employ Autodesk
products for this application. Creating maps and storing object's attributes
into the database is the easy part - I need advice on how to proceed with
routing, GPS integration, driver navigation, etc. , or API which i can use
for future developing.
