Infrastructure Map Server Developer
Active Member
cesar.schneider
Message 1 of 1 (386 Views)
Loading line shapes from database
386 Views, 0 Replies
06-06-2010 07:42 AM
I'm using Mapguide Enterprise and SQL Server 2008 and I want to create a layer with some lines using coordinates from database.
I've tried using OSGeo FDO Provider for ODBC, but I can only create points, not lines.
After setup a data connection, I'm able to set a table to use as geometry feature class, but when I'm creating the layer, it recognizes that data resource only as POINT and not as LINE.
I also tried to create a table with a geometry column and added a line record, but I'm not able to create a line using this table.
I would appreciate any ideas and suggestions about how to implement this.
Thank you.
