The simplest (not necessarily the best) method is to use the out-of-the-box
hyperlink capabililty. Make your URL field in your SDF file either the full
path or the file name. Then, when authoring the layer, select the URL field
to be the URL. You could add the path prefix at this point, eg,
'http://yoursite/yourdocs/'+URL or '\\yourserver\yourdocs'+URL
Once authored this way, when the users are viewing the map, the cursor
changes to a hand when floating over an object with a URL. Double-clicking
on the object will open the document in the URL target window.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
wrote in message news:5104393@discussion.autodesk.com...
What would be the simplest method to link a polygon in a SDF to a relevant
word doc or a bitmap? I would like to click the polygon and then run a
report that would directly open the associated document.
Steven
