GOOD DAY, I AM WITH PROBLEMS WITH LAYER SELECTION. IT WOULD LIKE TO KNOW IF SOMEBODY KNOWS WHAT IT CAN BE, WHERE IS THE ERRO.SEGUE THE CODE BELOW:
<!-- body class="AppFrame" onLoad="OnPageLoad()" --> <?php include 'common2.php'; include 'chamando_mapa.php'; $args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST : $_GET; $sessionId = $args['SESSION']; $mapName = $args['MAPNAME']; try { MgInitializeWebTier ($configFilePath); $userInfo = new MgUserInformation($sessionId); $siteConnection = new MgSiteConnection(); $siteConnection->Open($userInfo); $map = new MgMap($siteConnection); $map->Open($mapName); $queryOptions = new MgFeatureQueryOptions(); $queryOptions->SetFilter("DEN_ATU = 'FRANCISCO REBOLO R'"); $layer = $map->GetLayers()->GetItem('eixos'); $featureReader = $layer->SelectFeatures($queryOptions); $layer = $map->GetLayers()->GetItem('eixos'); $selection = new MgSelection($map); $selection->AddFeatures($layer, $featureReader, 0); $selectionXml = $selection->ToXml(); } catch (MgException $e) { echo $e->GetMessage(); echo $e->GetDetails(); } ?> <script language="javascript"> function OnPageLoad() { var selectionXml = '<?php echo $selectionXml; ?>'; xxx.mapFrame.SetSelectionXML(selectionXml); xxx.ExecuteMapAction(10); } </script> <body> <input type="button" name="ddd" value="" onclick="OnPageLoad();" /> <br/> <iframe style="width:800px;height:600px" id="xxx" name="xxx" src="/mapguide2010/mapviewerphp/ajaxviewer.php?SESSION=<?php echo $sessionId; ?>&WEBLAYOUT=<?php echo $homologLayout; ?>"> </iframe>
WHEN CLICO IN THE BUTTON IT APPEARS WITH 01 FEATURE SELECTED, BUT HE IS NOT NOTHING SELECTED, THEREFORE IN THE PROPERTIES IT DOES NOT APPEAR NOTHING.
PLEASE WHO WILL BE ABLE TO HELP IS THANKFUL ME IMMENSELY.
RATEFUL
CARLA TRAPÉ
Hi Carla.
If you're using Map Guide Enterprise 2010, look at Dev Guide manual, between pages 53 - 55. There's an example of how to select a feature. You can find it at %programfiles%\Autodesk\MapGuideEnterprise2010\WebServerExtensions\Help.
I think you can find the same file (DevGuide.pdf) if you're using another MapGuide's version.
You're getting the layer but you're not reading it. Check the method ReadNext().
Any doubts please let us know.
Jorge Olimpia
Brazil
