Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
KML Download file
2 REPLIES 2
swimming123
673 Views, 2 Replies
KML Download file
MapGuide Open Source2.5 has a great function is download the markup as kml/kmz file; but there's a small bug need to fix: you can display your kml/kmz using Quantum, ArcMap etc, but it cannot be display correctly using Google Earth. The reason: there's extra common symbol at end of each coordinates values. If you remove these common symbols, it can display correctly. So how to fix this? Thx.
2 REPLIES 2
in reply to: swimming123
A completely "Do at your own risk. Do not expect support" method you could try:
Swap out the installed MgRenderers.dll with the copy from MGOS 2.5
- Jackie
reno.sun.gis
Hello swimming123
Did Jackie's suggestion work for you?
