Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
javascript message box (interesting problem)
5 REPLIES 5
261 Views, 5 Replies
I seem to have coded myself into a silly situation. I have a function in javascript working exactly as I want, but for a unneeded alert box!
I added a message box for troubleshooting and now have the function working the way I want it to.
BUt now, if I remove the message box, the function does not seem to work.It seems like th user input of OK on the message box triggers the function to continue.( would that be possible?)
How do I get out of this? Please help.
function zoomFeature( ){
var map = getMap();
map.setAutoRefresh(false);
numRows = GetName.getRowCount();
for (i=0;i var templat = GetName.getField(i,"lat");
var templon = GetName.getField(i,"lon");
var tempfacil = GetName.getField(i,"faciid");
//alert(" done setting variables"); //I WANT TO REMOVE THIS MESSAGE BOX
if (tempfacil == "campus") {
map.zoomScale(templat,templon,10000);
else {
map.zoomScale(templat,templon,800);
self.focus();
map.setAutoRefresh(true);
map.refresh();
//alert("done");
5 REPLIES 5
Hi Swati
Please check the ismapbusy section to solve your
problem.
Your alert message indirectly "solved" the
ismapbusy problem that is why it is work when your alert box is
there.
Take alook at API help under section mapbusy.
It explain and give some example on how to do it
Hopefully it works
Regards
snapple
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
I
way I want it to.
How do I get out of
this? Please help.
var map = getMap();
for
(i=0;i<numRows;i++){
var
var tempfacil =
 else {
self.focus();
map.refresh();
//alert("done");
thanks for your message.I tried what you said and I do agree the map is
busy when I try to run the funcion. Now how do I wait for it to get out
of that state and try again?
is'nt my setautorefresh to false taking care of it?
Thanks a lot
swati
Snapple wrote:
 Hi Swati Please
check the ismapbusy section to solve your problem.
Your
alert message indirectly "solved" the ismapbusy problem that is why it
is work when your alert box is there.
 Take
alook at API help under section mapbusy.  It explain and give some
 Hopefully
it works
Regardssnapple
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">"swati"
<swatip@stanford.edu> wrote
in message news:f1140c9.-1@WebX.maYIadrTaRb...I
var map = getMap();
for (i=0;i<numRows;i++){
BOX
 else {
self.focus();
map.refresh();
//alert("done");
thanks for your message.I tried what you said and I do agree the map is busy when I
try to run the funcion. Now how do I wait for it to get out of that state and try again?
Thanks a lot
swati
well setAutorefresh not necessary taking care of it
when you chech using isMapBusy put condition if yes
to call the function you want again but better if you use timer
Meaning,
function hello()
   if (map.isBusy())
setTimeout("hello()", 1000);
    else
   --do something you want
here--
Regards
snapple
thanks
and try again?
Thanks a lot
swati
Hi swati I am facing the same problem in javascript?
If you have solved it please do tell me.
