Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Is it possible to make a click event to fire the Maptip than a mouseover
3 REPLIES 3
Bruce.Harris
499 Views, 3 Replies
I have an iframe in a Maptip which works fine in the Desktop platforms in all browsers. When I tried opening it in the Mobile devices like iPad or any other android tablets, the Maptip seems to be not working. I think the reason for this is there is no mouseover option in the Tablets or iPad. I believe that if a click event is fired rather than a mouseover event, it should work just fine.
Any thoughts will be helpful and much appreciated.
Cheers
Dom
3 REPLIES 3
jackie.ng
in reply to: Bruce.Harris
You are correct that there is no mouseover event for tablets because tablets have no mice, so such an event could never be raised.
Instead of mousemove, perhaps you could try triggering the map tip from the MAP_SELECTION_ON event raised by the map widget.
- Jackie
Bruce.Harris
in reply to: jackie.ng
Thanks  Jackie. I am not really sure about to make a call to trigger map tip from the MAP_SELECTION_ON event. I went through the JS files. But as I am not an expert with this, I could not really understand the code. Could you please explain it a bit more.
Many Thanks
Dom
gluckett
Check out: http://trac.osgeo.org/fusion/wiki/MapGuideTutorial
Put the code in the INDEX.HTML of the Fusion template (such as: C:\Program Files\Autodesk\Autodesk Infrastructure Web Server Extension 2015\www\fusion\templates\mapguide\aqua\index.html)
For example: in the var fusionInitialized = function()
you can add:
var theMap = Fusion.getWidgetById('Map');
theMap.registerForEvent(Fusion.Event.MAP_SELECTION_ON, selectionOn);
this will call a function called "selectionOn"
then you can call:
function selectionOn() {
theMap.getSelection(displaySelection);
And you can use the displaySelection from the demo on:
