Does anyone try to install AIMS 2017 (MgServer + WebExt + IIS/.Net) on Windows 10?
I tried three times with the default installation option with no success, if failed on the AIMS Web Extensions phase, and rolled back everything.
2016/7/25:15:45:09 Francisco ENVYFJRD Install Autodesk Infrastructure Map Server 2017 Succeeded
2016/7/25:15:45:09 Francisco ENVYFJRD Installing Autodesk Infrastructure Web Server Extension 2017: TRANSFORMS="C:\Users\FRANCI~1\AppData\Local\Temp\_AI1CCF.tmp\x64\Web\Web-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Map_Server_2017_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Infrastructure Web Server Extension 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/7/25:15:46:38 Francisco ENVYFJRD Install Autodesk Infrastructure Web Server Extension 2017 Failed Installation aborted, Result=1603
2016/7/25:15:46:49 Francisco ENVYFJRD Rollback Autodesk Infrastructure Map Server 2017 Succeeded
2016/7/25:15:46:49 Francisco ENVYFJRD Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/7/25:15:46:49 Francisco ENVYFJRD Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/7/25:15:46:49 Francisco ENVYFJRD Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2016/7/25:15:46:49 Francisco ENVYFJRD Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2016/7/25:15:46:52 Francisco ENVYFJRD PageOpen InstallCompleteDialog
So I had to go manually , first install AIMS Server, and then AIMS Web Ext for manual configuration.
After that I followed this : Configuring Infrastructure Map Server Web Extensions on Windows
Also new licensing model impacts, you must run AIMS Licensing Activator prior to start a trial period , otherwise the following exception is thrown:
<2016-07-27T16:18:22> 9516
Error: Problem:\nThe application encountered a problem and could not finish the operation you just requested properly.\n\nSolution:\nIf it\'s the first time you met this problem, try again or restart the application / session; otherwise, describe the steps to reproduce this problem to the server administrator for suggestions.
StackTrace:
- MgServer.open() line 1300 file e:\build\2017\re_ims2017_46_1-6376417\ent\os\server\src\core\Server.cpp
- MgLicenseManager.Initialize() line 233 file e:\build\2017\re_ims2017_46_1-6376417\ent\server\src\common\manager\LicenseManager.cpp
More about new licensing model:
Licensing-Infrastructure-Map-Server-2017-changed.html
Best Regards,
Yes,
u'll have 2 follow step by step Install instructions from - http://help.autodesk.com/view/AIMS/2017/ENU/?guid=GUID-FADAAA63-222C-4586-B2D1-7093E6F82671
