Infrastructure Map Server Developer
New Member
basilfish
Message 1 of 8 (2,043 Views)
Infrastructure Map Server 2013 on Windows Server R2 Standard
2043 Views, 7 Replies
07-20-2012 06:47 AM
The system requirement for the above product as shown in the document
System Requirements (64-bit)
Operating System
• Server components: Windows Server® 2008 Enterprise, Service Pack 2 (SP2)
Question: is there a difference if the product is installed in Windows Server 2008 R2 Standard?
Board Manager
Daniel.Du
Message 2 of 8 (2,037 Views)
Re: Infrastructure Map Server 2013 on Windows Server R2 Standard
07-23-2012 01:08 AM in reply to: basilfish
Windows Server® 2008 Enterprise is the officially supported OS, but I expect it runs on Windows Server 2008 Standard as well, although is it not officially supported.
Daniel Du
Developer Technical Services
Autodesk Developer Network
Member
ahgaitana
Message 3 of 8 (1,989 Views)
08-13-2012 11:09 PM in reply to: basilfish
Hi Daniel,
Is Infrastructure Map Server2013 will still work for Windows Server 2003 R2 standard?
We also use IIS6 as our services? will still run?
Buddy
Board Manager
Daniel.Du
Message 4 of 8 (1,985 Views)
08-13-2012 11:19 PM in reply to: ahgaitana
Hi Buddy,
AIMS 2013 is only tested on the OS which is described in the system requirement document, it may run on other OS, but please note that it is not officially supported.
I personally did not try Windows Server 2003 with IIS6, so I have no say about it, I tried on Windows7, it works, of cause it is not suitable for production environment.
Hope this clarifies.
Daniel Du
Active Member
dale.dianzon
Message 5 of 8 (879 Views)
05-16-2013 01:39 AM in reply to: basilfish
Hello SIr,
Good day! We would like to inquire for technical documents or manual for installing Web Server extensions and Several
Site Servers on different separate servers, also the configuration on how to load balance the multiple site servers.
Thank you very much.
Board Manager
Daniel.Du
Message 6 of 8 (878 Views)
05-16-2013 01:48 AM in reply to: dale.dianzon
This site should be helpful:
http://sandbox.mapguide.com
especially this page for load banlancing
http://sandbox.mapguide.com/index.php/Pragmatic_Load_Balancing
Daniel Du
Active Member
dale.dianzon
Message 7 of 8 (876 Views)
05-16-2013 02:00 AM in reply to: Daniel.Du
Sir,
Good day! We have already done what is written on the following:
but unfortunately load balancing does not work, the load is only focused on one server. Maybe you have
some further details.
Thank you.
Active Member
dale.dianzon
Message 8 of 8 (873 Views)
05-16-2013 02:15 AM in reply to: dale.dianzon
Hello Sir,
Good day! We would also like to know the proper server sizing for AIMS 2013 in terms of single server (Web and MapServer on one machine) and also for separate server setup, in pragmatic mode.
Thank you.
