Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
incompatible data resource(sql server) MapGuide studio 2007
2 REPLIES 2
266 Views, 2 Replies
Hi:
I have a mapguide application running on mapGuide6.5 i am trying to upgrade
it to mapeGuide2007 so i am using the mapGuide studio to create my maps but
i am facing a problem with the data resource created from FDO sql server
provider as when ever i am trying to make a layer with this resource i
always recieve the message "you are about to change to an incompatible data
resource proceed and reset to defaults" I acnn't configure out what is wrong
please help??
All what i am trying to do is to make a point layer from a sql server data
base table?????
Thanks in advance
2 REPLIES 2
I am running into the same problem. Has this issue been resolved???
jumpinjackie
That message is normal.
When you switch a layer's underlying feature source, if the properties the layer is referencing in the previous feature source do not exist in the new feature source, then Studio will warn you with that cryptic message.
Also have you specified the table in question as a Geometry table? Have you specified the X and Y columns?
- Jackie
http://themapguyde.blogspot.com
http://au.linkedin.com/in/jackieng
