Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
IMS 2013 - Issues with Selecting Features
0 REPLIES 0
Message 1 of 1
286 Views, 0 Replies
I am working in a Windows Server 2008  R2 with IMS 2013 installed.
I was able to create an SDE connection after adding in the dlls required for SDE (pe.dll, sde.dll, sg.dll) in the FDO folder.
I was able to create a layer based off this data connection and was able to view it. The problem I have is that I can't select anything from this layer.
The other issue I have is with  the Oracle King provider connection. Like above, I am able to create the connetion, create the layer for the connection and view it. The issue with this though is that if I have features close to each other, only 1 feature will be selectable. It's like the bounding box is bigger than the feature itself.
Any solutions would be helpful.
0 REPLIES 0
