Hi using the Raster Workshop, I have created a tiff in the correct coordinate system. When I try to add this raster file to my map, I get the warning: An error was encountered. The request will not be processed, There is no further information provided. Does anybody know why I get this error?
Michael Kohler
As I know there is some problems with raster tiff. Try to insert for instance in raster design check it, save or export. and try again.
Also try to creat tiff with raster workshop compress/uncompress .
Kalmy
Thanks, for the reply. I ended up using the Mr. Sid images instead and it worked fine.
