Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
I Can't login in MG Studio
8 REPLIES 8
Message 1 of 9
552 Views, 8 Replies
i'm having a huge problem that i can't resolved it. I've install MP Enterprise and then MP Studio but not with any license, and i've choose IIS installation. After install i followed the instructions on "GettingStartedGuide.pdf" and "InstallConfigureMgEnterpriseOnWindows.pdf". I followed every step (i think) on these two manuals, but when i'm trying to open MG Studio, he ask me for the site and user and password. I enter the site that is on the IIS ( is mapguide2010) but it still don't work. It keep saying: "Unexpected error in contacting site URL".
If someone knows what i did wrong, please tell me.
8 REPLIES 8
Message 2 of 9
Please have a look at:
C:\Programme\Autodesk\MapGuideEnterprise2010\Server\Logs\Error.log
Any errors?
Message 3 of 9
This is what i got in my Error.log
# Log Type: Error Log
# Log Parameters: CLIENT,CLIENTIP,USER,ERROR,STACKTRACE
<2009-10-15T14:42:04> 3216
Success: Server started.
<2009-10-16T17:16:29> 4924
<2009-10-19T17:09:37> 3600
<2009-10-20T16:54:57> 4152
<2009-10-20T17:55:44> 3532
<2009-10-22T17:28:13> 1972
I think i don't have any error, but i still can't connect to the site...
Message 4 of 9
dswilson
So just to check is Studio on the same machine as the server or another machine?
The URL you should be entering into studio should look like:
http://servername/mapguide2010/ or http://(ipaddress)/mapguide2010
Do you have a firewall blocking requests to IIS on the machine? Is http or port 80 open?
Dave
Message 5 of 9
Yes the Studio and the server are in the same machine. I've tried to log in, in studio these 2 ways;
http://localhost/mapguide2010 and http://127.0.0.1/mapguide2010
These two hays didn't work.
How do i see if my firewall is blocking the iis? and how do i know if my port 80 is open?
Message 6 of 9
dswilson
If they are on the same machine then localhost and 127 requests shouldn't be blocked by the firewall. I'm guessing you are running windows XP.
From the Control Panel you need to access the Firewall and maybe add entries for ports 2800, 2801 and 2802 which are used between the server and the web tier. You can prove this by quickly disabling the firewall and trying to connect.
Dave
Message 7 of 9
yes i'm using XP. is that a problem?
I disable the firewall, added the ports, but still the same error...
I'm freaking out! what should i do?
Message 8 of 9
dswilson
Some ideas:
1) Check the System Even log under Applications and see if there are any errors.
2) Try the following URL in a browser: http://localhost/mapguide2010/mapagent/index.html. Execute the EnumerateResources by hitting the submit button the default page.
3) Can you log into the Site Admin: http://localhost/mapguide2010/mapadmin/login.php
4) Which instance of the API did you install? PHP or .NET. If you previously had 2009 installed check your system path for an entry pointing to PHP in a 2009 folder and remove the entry.
5) Try reinstalling the WebExtensions using Apache instead and add the :8008 port to the URL.
Dave
Message 9 of 9
Guy's i resolved my problem!!!!
One of you asked me, if i was using windows XP. yes i was using windows XP but it was the Media Center!!!! So i install the XP Pro and it work at first time!!!!
Thanks a lot guys!!!
Cheers
