Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
How to use fusionSF.js functions
1 REPLY 1
swimming123
778 Views, 1 Reply
Hi there,
 fusionSF.jsis a big file, it includes lots of functions, so how to use these functions in my new widget? How to understand this file? for example, try to use drawPoint method, it accept 3 parameters geometry, style, featureId;  then how can I define the geometry just based on x, y and coordinates system such as EPSG:4326?
I can upload a file to draw many points on a exsiting map using OpenLayers, but how to do similar job in AIMS2013 Fusion Viewer? Thank you.
1 REPLY 1
gluckett
in reply to: swimming123
There is limited value here:
http://trac.osgeo.org/fusion/wiki/Documentation
but Daniel's blog is really good for API:
http://adndevblog.typepad.com/infrastructure/daniel-du/
And if you want MapGuide Open Source help, check out Jackie's:
http://themapguyde.blogspot.ca/
