Infrastructure Map Server General Discussion
Valued Contributor
swimming123
Message 1 of 2 (517 Views)
How to use fusionSF.js functions
517 Views, 1 Replies
10-24-2012 12:47 PM
Hi there,
 fusionSF.jsis a big file, it includes lots of functions, so how to use these functions in my new widget? How to understand this file? for example, try to use drawPoint method, it accept 3 parameters geometry, style, featureId;  then how can I define the geometry just based on x, y and coordinates system such as EPSG:4326?
I can upload a file to draw many points on a exsiting map using OpenLayers, but how to do similar job in AIMS2013 Fusion Viewer? Thank you.
Valued Mentor
gluckett
Message 2 of 2 (462 Views)
Re: How to use fusionSF.js functions
11-01-2012 07:02 AM in reply to: swimming123
There is limited value here:
http://trac.osgeo.org/fusion/wiki/Documentation
but Daniel's blog is really good for API:
http://adndevblog.typepad.com/infrastructure/daniel-du/
And if you want MapGuide Open Source help, check out Jackie's:
http://themapguyde.blogspot.ca/
