Infrastructure Map Server General Discussion
Valued Contributor
swimming123
Message 1 of 1 (364 Views)
How to use Fusion API for creating points layer
364 Views, 0 Replies
10-18-2012 03:01 PM
How to create points in the client side by input lonlat values? I try use following code:
           var mgApiMapWidgetId = 'Map';
            var MainFusionWindow = GetFusionWindow();
            var pointsLayer = MainFusionWindow.OpenLayers;
            var Fusion = MainFusionWindow.Fusion;
            var mapWidget = Fusion.getWidgetById(mgApiMapWidgetId);
            var map = Fusion.getWidgetById(mgApiMapWidgetId).oMapOL;
            alert("a");
            pointsLayer.LonLat.fromString("51.2356, -114.235689");
            alert("aa");
            map.addLayers([pointsLayer]);
            alert("aaa");
It can alert to "aa". That means last step not success. Do I need add SRS from the current map? Thank you.
