I am new to MapGuide Enterprise Development and I am working on a project in MapGuide 2009. I need to display the records from the Database (SQL Server 2005) in to the properties box. Can it be done ?
Moreover, I have created a New InvokeURL which calls the display.aspx file to display the records in a new window. But when I select a feature from the map, the same number should get displayed in the dropdownlist present in the display.aspx file, which is not happening. How to do it?
Please, KINDLY someone come to my aid.
Solved by gluckett. Go to Solution.
In theory you should be able to connect the table to your feature souce using a JOIN.
For Layer Definition:
Now that the Join is created, be sure to choose the correct "Feature Class" in you Layer Definition - so that all the joined columns will appear. Then click SELECT ALL for Properties Displayed in Viewer. That way when you select a feature, you can see all the SQL Server features.
