i've got the same problem: I made a search custom search option which results are shown in the taskpane. The zoom to feature works fine, but the scale is 1:1. In ajaxmappane.templ i changed the minScale to 150 but nothing changed in the weblayout...
Any ideas where i have to make another change in my code?
I'm using MapGuide Enterprise 2011 with fusion weblyout (slate).
Best regards
If you use basic layout then you havte to change ajaxmappane.templ but when using flexible layout(fusion) theb you need to make changes in LoadMap.php in the fusion\layers\MapGuide\php folder.
http://sandbox.mapguide.com/index.php/Setting_minimum_and_maximum_scale
I got it working.
