hello ,
I am having a drawing in autocad which have to convert to mapguide, in which 1 layer is having objects as line , point , polygon. have to export this files into shp but the problem is i have to select any1 of the options TEXT|POINT|LINE|POLYGON.
i have to use this layer with the same name.
is it possible to export all the objects into 1 shp file....i am using AUTOCAD MAP 2004. , MGE 2007.
please reply soon.
cheers
teja
