Hi Jason,
I can recommend this "cheap" software, it's very reliable and has worked
fine for us for more than a year in production.
http://www.ks-soft.net/hostmon.eng/index.htm
It can check your webserver, webpages, files on the disk, diskusage, windows
services etc.
It can notify you via email, pager, sms, wap etc.
It can execute any program or restart services at any event I can think of,
pretty much all-around software.
If you use .NET then you can easily do a windows service monitor yourself,
just a few lines of code to email yourself if a service goes down and
automatically restart it. There are much information on the net, use Google.
Best regards,
Jocke
"Jason Birch" wrote in message
news:vc4ppvgmmipantan3rldsh47cg75hpa1mc@4ax.com...
> On Fri, 24 Oct 2003 15:32:21 -0700, in autodesk.mapguide.developer
> "Meng Li" wrote:
> > Anyone had experience in catching and tracking MapGuide server errors,
> > especially those servere errors that may cause MapGuide server not
running,
> > and send them to administrators via email for actions?
> As far as I have seen, there is no native way of doing this in
> MapGuide. However, if the services are actually failing (in a way
> that Windows is aware of) then you can set up notification through the
> Services control panel item.
> Select the MapGuide (or JRun or whatever) service, right click, choose
> Properties, and then click on the Recovery tab. There, you have the
> option to run a file when the service stops. You can send an email
> from this file, do a NET SEND, and/or restart the service (NET START)
> Here's a pretty clear example of how to send the email using Windows
> scripting: http://www.paulsadowski.com/WSH/cdo.htm There are also a
> number of free utilities that could accomplish the same.
> If you're seeing specific errors in the event log associated with
> these errors, then you could set up some kind of event log monitoring.
> SQL Server has the ability to do this internally, and there are quite
> a few commercial event log monitors out there.
> Jason
