Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Highlight selected MySQL objects
6 REPLIES 6
Peter65
358 Views, 6 Replies
Hi @all,
and thanks for creating this group :-).
Here my first question. Sorry for cross post (OSGeo) but the following problem is unsolved:
I've loaded geometry objects from MySQL database. The connection to the database is possible. Also the geometry is shown. But when I select one line, all lines of the layer are highlighted. Interesting is, that the tooltip works correctly.
Here is a code example for inserting the lines into MySQL:
insert into tra_strasse_geometrie(strageo_geo, strageo_name_id) Values (geomfromtext('linestring(4531094.71 5686671.65,4531027.17 5686674.21)'), 7);
The table "tra_strasse_geometrie" is of MyISAM type and the row "strageo_geo" is of type GEOMTERY with index.
I'm using MySQL 5.0.24, MGOS 1.0.1, MG Studio 1.0.0, AJAX viewer.
Sorry, but I'm new with MGE and MySQL too.
Thanks in advance.
Regards - Peter
6 REPLIES 6
Peter65
in reply to: Peter65
Hi @all,
after installing SP1 for the studio and using MGOS 1.0.2, a part of the problem is solved. But only a part: selecting an object leads to highlighting it.
But now I have an other problem. The selection is sometimes not correct. I want say, moving the cursor over one object, the tool shows the information of an other object an select and highlight the other object.
Can anybody help?
Thanks in advance - Peter
Probably not much help, but we have a dataset that exhibits similar
behavior. The zoom-to function zooms to and selects the correct feature,
but the report in the Properties pane displays data for an adjacent
feature (which always has a key value that is one greater or less than the
key for the selected object).
This can be seen at < ="">, do an address
search (for "1040" as an example) and then zoom to various parcels in the
result set. For example, zooming to 1040 Monterra Ln produces a report for
1119 DeMoll Dr.
James Card
Peter65
Thanks for reply. What FDO are you using. I ask, because I have this behavior with MySQL. When I use the same geometry from shape-files, then it works fine.
Best regards - Peter
> it works fine.
Data was originally shapefiles, but we had MapGuide Studio convert it to
SDF when it was loaded into the repository.
James Card
Peter65
With shapefiles I had no problems (exported from Autodesk MAP). Only with MySQL.
However I found a first solution :-). Yesterday I installed the dwf-viewer and it works fine :-)!!! Perhaps this could help you too?
i think till now you will beccome master in mysql and mapguide studio and data connectivity bt i don't know anything about connectivity ,please guide me .what is procedure of data connection
thanks
