Hello everyone.
i am experiencing a trouble with a message from google maps everytime i interact or load a google maps basemap.
if i zoom, the message appears, if i move, the same issue.
this happens with AIMS 2013 bot in mobile and desktop web clients.
is there a fix for this?
thank you for your Help
W. Herrera
Solved by gluckett. Go to Solution.
Solved by jackie.ng. Go to Solution.
Assuming that viewer is using OpenLayers 2.11, just patch the library like so:
https://github.com/openlayers/openlayers/commit/92f04a7a4277a6c818ef2d40a2856910ed72d3d6
or like this
http://trac.osgeo.org/openlayers/wiki/Release/2.11/GoogleMaps37
- Jackie
thanks for the quick response! the fastest way to fix this problem was with the solution Gordon Posted.
after a while i tested Jackie solution and this also works!.
thank you very much.
Wilson H
Hello Everyone,
The solution works well on IMS2013 desktop environment, but I cannot remove the google popup window from MobileViewer Extension.
Someone does it work?
Thanks for advance,
Tamas
