Infrastructure Map Server General Discussion
wilsonherrera
Message 1 of 6 (1,711 Views)
Google Message inside Mobile Viewer - General Google Maps overlay
1711 Views, 5 Replies
09-06-2012 02:39 PM
Hello everyone.
i am experiencing a trouble with a message from google maps everytime i interact or load  a google maps basemap.
if i zoom, the message appears, if i move, the same issue.
this happens with AIMS 2013 bot in mobile and desktop web clients.
is there a fix for this?
thank you for your Help
W. Herrera
Valued Mentor
jackie.ng
Message 2 of 6 (1,707 Views)
Re: Google Message inside Mobile Viewer - General Google Maps overlay
09-06-2012 08:35 PM in reply to: wilsonherrera
Assuming that viewer is using OpenLayers 2.11, just patch the library like so:
https://github.com/openlayers/openlayers/commit/92f04a7a4277a6c818ef2d40a2856910ed72d3d6
or like this
http://trac.osgeo.org/openlayers/wiki/Release/2.11/GoogleMaps37
- Jackie
Valued Mentor
gluckett
Message 3 of 6 (1,684 Views)
09-12-2012 07:19 AM in reply to: wilsonherrera
wilsonherrera
Message 4 of 6 (1,580 Views)
10-09-2012 01:01 PM in reply to: wilsonherrera
thanks for the quick response! the fastest way to fix this problem was with the solution Gordon Posted.
after a while i tested Jackie solution and this also works!.
thank you very much.
Wilson H
New Member
katonat
Message 5 of 6 (1,351 Views)
11-09-2012 08:06 AM in reply to: wilsonherrera
Hello Everyone,
The solution works well on IMS2013 desktop environment, but I cannot remove the google popup window from MobileViewer Extension.
Someone does it work?
Thanks for advance,
Tamas
Valued Mentor
jackie.ng
Message 6 of 6 (1,325 Views)
11-11-2012 06:51 PM in reply to: katonat
It's probably using its own version of OpenLayers that needs to have the same patch applied
- Jackie
