Tested MGE 2011 and AIMS 2012 with Fusion Slate template.
Source layers are in a half dozen different coordinate systems.
Map definition coordinate system is set to UTM83-17. Also tried with other systems.
When I set the viewer options to display degrees, the lat/lon values are invalid. Should be around -82 longitude, displays 4.
If I set the map definition to LL84, the viewer displays the correct lat/lon values.
Anybody else seen this?
Yes, and it plays havoc with the measure tools as well. Set your map to LL84 or Spherical Mercator and the problem goes away, I think the FUSION (Flexible Web Layouts) doesn't work well with most non-geodetic coordinate systems (links back to OpenLayers)
Thank you for confirming this problem. Since others are having the same trouble, I will start digging a little deeper.
