Infrastructure Map Server General Discussion
Active Contributor
0 Kudos
Post 1 of 4
Fusion Legend Item Off While Displayed in Map???
332 Views, 3 Replies
10-07-2011 11:10 AM
I have Mapguide 2011 Fusion web map that when the map initially loads it shows the layer in the map, but in the legend it is unchecked. It has to be checked and unchecked a few times to actually reflect chnages in the map.
In Studio I have the layer set to initially draw when the map loads as well as the layer to display in the legend. It is like the legend is not recognizing the layer is there until the user check and unchecks the legend.
Any insight would be greatly appreciated!!
Thanks!:smileyvery-happy:
emluv
Valued Mentor
74 Kudos
Post 2 of 4
Re: Fusion Legend Item Off While Displayed in Map???
10-11-2011 09:20 PM in reply to: emluv
In the index.htm page of each of the Fusion Templates, you can add a refresh to the initPanelHandle function
var theMap = Fusion.getWidgetById('Map');
theMap.reloadMap();
Active Contributor
0 Kudos
Post 3 of 4
10-12-2011 07:22 AM in reply to: emluv
Thanks Gordon!
Is the index.htm file in the \WebServerExtensions\www\fusion\templates\mapguide\aqua folder? I see an index.html file in this folder, is this the one to edit?
I appreciate it:smileyhappy:
emluv
Valued Mentor
74 Kudos
Post 4 of 4
10-12-2011 07:35 AM in reply to: emluv
Yes, that's the one.  Around line 179 in
 var initPanelHandler = function() {
