Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Fusion (FlexibleLayouts) gives configloaderror
3 REPLIES 3
876 Views, 3 Replies
I am using MapGuide Open Source Server with Autodesk MapGuide 2009 and I am testing my install using the samples.
For the Sheboygan sample I can view in the browser all of the samples in the Layers, but can't view any of the FlexibleLayouts.
When I view the flexible laysouts I get a box with the message "configloaderror".
Any ideas??
3 REPLIES 3
Fixed it.
I had to add MIME type .json as application/json to the HTML/MIME types in IIIS
Thank you owensr23! You tip solved my problem.
Daniel.Du
Reiterate this with detail:
     		- goto "Properties" of your fusion virtual directory in IIS  manager
     		- select "HTTP Headers" tab
     		- select "MIME Types..." button
     		- click "New" button
     		- enter:  		Extension:   .json
     			  		MIME type:   application/json
     	        - click "Ok"
Daniel Du
Developer Technical Services
Autodesk Developer Network
