Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
291 Views, 2 Replies
Fusion Error
We have 2009 loaded and we are getting an error that appears when we load more than 11 layers. The error is:
Fusion Error
Warning Exception occurred in AJAX callback
[object error]
xx)
Any suggestions would be great!!!!
Kristy
2 REPLIES 2
i am facing the same problem!
dreamcon
I have had the same error. One thing you might want to check is to see if your primary and/or your secondary toolbar are forced on to two lines. That is what was happening with me so I removed some items from the secondary toolbar and presto it worked.
Paul Flemming
