Hi guys,
I installed a trial version of mapserver2014. I imported some data from Map 2014 through the Publishing tool without any problem.
Nonetheless, when I try previewing the map in Infrastructure Studio, or when I try displaying the map in a fusion Topobase web layout (or any other web layout), I get this error:
Fusion Error:
WARNING: Exception occurred in AJAX callback.
JSON.parse: unexpected character
When I try debugging through Firebug, I can see a call back saying:
ERROR: Session has expired or is invalid. Please log in again.
The session (540d67fc-0023-11e3-8000-6c3be50ec411_en_MTI3LjAuMC4x0AFC0AFB0AFA) has expired.
- MgSiteManager.GetConnectionProperties() line 339 file f:\build\ims2014_knight\build_76.1\ent\os\common\mapguidecommon\Services/SiteManager.cpp
I'm using a Win7 64 bits machine with IIS 7
Do you have any idea what could be happening?
Maxime
Check your Folder Names and Layer Name. Remove all Spaces, commas, exclaimation marks or anything weird.
Just use letters and underscores for your layer names and group names in your maps. You can change the LABEL to anything but not the names.
This might fix your errors on your map.
