Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Fusion customization
3 REPLIES 3
swimming123
1449 Views, 3 Replies
Hi there,
I am new to use map server infrastructure. How can I learn to do customization in fusion? Any book or something I can buy? Thanks.
3 REPLIES 3
in reply to: swimming123
What exactly are you trying to customize?
Look and feel? Hack and play around with the css/html of one of the fusion templates
Functionality? Create your own InvokeURL and InvokeScript widgets, and add them into your Flexible Layout
- Jackie
swimming123
Hi Jackie I want to create a widget for this task: cusomter click on the map for any specific location, my function can query several hundred of layers and create a report for cutomers. So customer can based on the report to make a decision. Easy to use spatial data instead of reading my hundred of layers and their attribute values behind. So this task has several steps: - create a layer resource for the point of interest; - doing the query between new point layer and my exsiting layers; - Response.Write the results in a format like table; Pretty tough for me because I am beginner. Can you help me with this task. Thank you.
Daniel.Du
Have you ever checked this DevTV on Infrastructure Map Server developer center?
DevTV: MapGuide Fusion Technology Introduction
A self-paced video tutorial on how to build a web-based mapping application using the Fusion Viewer Technology and MapGuide Enterprise.
View Online | Download
Daniel Du
Developer Technical Services
Autodesk Developer Network
