Infrastructure Map Server General Discussion
Valued Contributor
nik.mazreen
Message 1 of 5 (430 Views)
flexible layout
430 Views, 4 Replies
06-05-2011 06:44 PM
i had a problem with flexible layout. after i set everything for my flexible layout, error shown below appeared when i try to save my layout. can anyone help me?
Thx in advance
-Nik-
s.klein
Message 2 of 5 (412 Views)
Re: flexible layout
06-08-2011 03:36 AM in reply to: nik.mazreen
the errormsg points that the coordinate system of your data isn't the same than in your map.
So i think you will have to reproject your data or change the coordinate system of your map.
S. Klein
Valued Contributor
nik.mazreen
Message 3 of 5 (404 Views)
Re: flexible layout
06-08-2011 06:08 PM in reply to: s.klein
Thx for the reply...at 1st, i though the same as yours..this error happen when i checked the Bing map (as shown in the picture earlier). if i didn't, it actually work perfectly fine when i save it.
Thx
-Nik-
Active Member
jerryr
Message 4 of 5 (396 Views)
Re: flexible layout
06-09-2011 06:13 AM in reply to: nik.mazreen
To use the Bing (or other commercial layer), the Map coordinate system needs to be WGS84 PsuedoMercator of the World/Continental category.  The other layers in your map will be reprojected to this on display.
Valued Contributor
nik.mazreen
Message 5 of 5 (320 Views)
Re: flexible layout
07-08-2011 02:15 AM in reply to: jerryr
It's solved...Thx all...
Now i have another problem..i'm using data that used "GCS_GDM_2000 (GCS_GDM_2000)" as their coordinate system.
the problem here is that, when i change the coordinate system to  WGS84 PsuedoMercator and publish it to google map, it does not appear at the right place. (as shown below) ..i've go through the coordinate system list, it seem that "GCS_GDM_2000 (GCS_GDM_2000)" is not listed in Coordinate System in MGE..how can i add this coordinate system into the MGE Coor. Sys..
 Thx
-Nik-
