Infrastructure Map Server General Discussion
New Member
0 Kudos
Post 1 of 3
Filtering Joined Data
307 Views, 2 Replies
01-17-2011 01:36 PM
I am trying to theme a layer based on a join between a SQL table via DSN and an sdf. I only want to return results where a uniqe ID field is equal to 9 as the SQL table consists of thousands of records that are irrelevant to this particular thematic. However when I try to apply a filter to the property which is an int32, i get an error message saying, "An exception occured in FDO component. Property 'CommunityID' is not found. I can't seem to get the filter to work for any of the fields in the SQL table. Any help?
Jaime
0 Kudos
Post 2 of 3
Re: Filtering Joined Data
02-11-2011 11:19 AM in reply to: jtorrsc
Don't know if you found a solution to this yet, we are experiencing a similar issue.
please let me know if you found a solution or if anyone knows. thank you!
Valued Mentor
74 Kudos
Post 3 of 3
03-11-2011 07:09 AM in reply to: SethStark
I have had similar issues, I usually have to create a view in SQL Server to remove the offending Fields that are causing the issue and join my data to that new view to work around it.
