Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
filter with OR and SpatialFilter
1 REPLY 1
nick_xu
535 Views, 1 Reply
my code does a query based on filter and within the goemetry selected.
If the filter is simple like "TYPE=1", then it works fine, but when Filter contains OR, then it will return all features and ignore the spatial filter.
queryOptions.SetFilter("TYPE=1 OR TYPE = 2")
queryOptions.SetSpatialFilter(geometryField, selectionPoly,
MgFeatureSpatialOperations.Intersects);
MgFeatureReader fr = this._featureService.SelectFeatures((newMgResourceIdentifier(themeLayer.FeatureSourceId)), themeLayer.GetFeatureClassName(), queryOptions);
the feature provider is autodesk.oracle.
I did another test using sdf based layer and it returned features inside selected geometry on both filter with or without "OR" situations.
1 REPLY 1
jackie.ng
in reply to: nick_xu
I think it may be the same problem as this one:
http://trac.osgeo.org/fdo/ticket/864
Basically, the FDO provider is not properly wrapping () around the translated non-spatial filter resulting in incorrect operator precedence when combined with a spatial filter.
- Jackie
