Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Filter case sensitive
3 REPLIES 3
234 Views, 3 Replies
I'm trying to create a search tool in the studio on a shapefile and sdf where all the content are uppercase. I was thinking that the operator LIKE was supposed to do the job, but it seems that no!
Is somebody know was is exactly the function to do that. I've tried Upper() but not working.
3 REPLIES 3
dswilson
Upper should be the correct function.
The expression in the advanced expression builder should look something like:
"PropertyName" LIKE Upper('%$USER_VARIABLE%')
Note I added wildcards to both sides of the expression. There is also a bug such that this doesn't appear to work with Extended characters such as é found in non-english languages.
Dave
Thanks Dave,
The problem was my upper synthax. Now it' work great.
Can you tell me in wich language are the expression builder?
Thanks again
dswilson
I don't think the expression is in any formal language syntax. It's FDO syntax as far as I know.
Dave
