I am trying to create a simple feature join. I have an SDF file and an
Access database. The key column in the Access database is a long integer
and I am trying to join on the SDF_ID also listed as int32. Every time I
create the join I get all the correct fields etc. in the Author. I soon as
I try to create a layer Iget a warning saying I am trying to connect to an
incompatible feature source. My SDF file is no longer usable for any layer
definitions.
The Feature Class seems to go missing. I assume this is the case as I no
longer get the full layer definition dialog box to show up in the Author. I
also tried to do this with a shp file and had the same problem. Here the
Author shows the full layer dialog but the Feature Source drop down is
blank.
This is a simple join of 10 records in a db table to 10 polygons, designed
to make as simple a test as possible.
I'm stuck! Any ideas?
