Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
failed to check out a license with AdLM code: 20
2 REPLIES 2
1380 Views, 2 Replies
Hello respected members autodesk, using a web interface topobase error "failed to check out a license with AdLM code: 20." The problem is this: a user1 has gone web interfase, but user2 can not enter, an error occurs:failed to check out a license with AdLM code: 20
Tell me please how to configure the system so that users can logon in web interface?
Thanks!
2 REPLIES 2
TravisNave
Definitely a strange one.
Have you tried these examples?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13894457&linkID=9242778
Or service pack updates?
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242779#section1
For faster responses concerning Autodesk licensing issues, please post your questions in the Installation and Network Licensing user forum here:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Thank you for your reply, unfortunately your answer did not help us, we do not have the server file CascadeInfo.cas most likely this is due to licenses on the server, we have the settings you can use only one license, but no such license web properties Requests from the same user/ host do not consume a new license.
