Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
External component has thrown an exception
3 REPLIES 3
1814 Views, 3 Replies
I am new to MapGuide and Autodesk Infrastructure Studio. I have setup OSGeo MapGuide on a server and it appears to work properly as I can view the samples and access the administration portal. I have accessed the site from Infrastructure studio and can modify layers, etc, but when I try to create a new data connection, I get an error saying "External component has thrown an exception". This happens on the Sheboygen sample as well as a new folder I have created. I have tried an OBDC connection and SDF and as soon as I select the feature provider and click OK, the above error shows up. I have attached the error details.Any help is appreciated.
3 REPLIES 3
I have loaded Autodesk Ifrastructure Studio on the server that has OS MapGuide running and am, at least able to get the dialog to open, but now get an error that I have posted on the MapGuide forum: http://forums.autodesk.com/t5/Autodesk-MapGuide/Cannot-Load-SDF-file/m-p/3607098. Could the original problem be due to me connecting to the server by way of a VPN?
Daniel.Du
It seems that this is not API related question, I would suggest you to ask in Autodesk MapGuide Enterprise board, where you may get more answers.
http://forums.autodesk.com/t5/Autodesk-MapGuide-Enterprise/bd-p/233
Daniel Du
Developer Technical Services
Autodesk Developer Network
in reply to: Daniel.Du
I am afraid I need to apologize. This turned into a "DUH" moment after I installed AIMS on a workstation tha meets the system requirements that was in the same domain as the OSGeo server.
Thanks you for replying, though.
