Infrastructure Map Server General Discussion
tony.witham
Message 1 of 3 (738 Views)
Exercises in Autodesk MapGuide Enterprise 2011 Getting Started Guide
738 Views, 2 Replies
11-19-2012 03:24 AM
I'm using Autodesk Infrastructure Studio 2013 (v2.4.0.5208) and I;m working through the exercises in the Autodesk MapGuide Enterprise 2011 Getting Started Guide using the Sheboygan sample data.  When I attempt the exercise to connect to an Access database everyhting appears to go fine until I click on 'Test Conncetion'.  I then get an error message :
An exception occurred in FDO component.
RDBMS: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
What am I doing wrong?
Valued Mentor
jackie.ng
Message 2 of 3 (720 Views)
Re: Exercises in Autodesk MapGuide Enterprise 2011 Getting Started Guide
11-20-2012 05:34 PM in reply to: tony.witham
If this is 64-bit MapGuide/AIMS, then the ODBC driver name may be different
- Jackie
Product Support
NateMoore
Message 3 of 3 (701 Views)
11-22-2012 07:36 AM in reply to: tony.witham
If you are on a server, or system without Office, you might not have any drivers at all.  http://www.microsoft.com/en-us/download/details.aspx?id=13255 will set you up with what you need.  Be sure to match the bit-ness of Map Server.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
