Does Autodesk MapGuide support .lyr (layer) files? If not, are there plans on adding the ability to see these services?
.lyr is not currently supported but MapGuide can import .shp, however this is not so useful for adding features with complex symbology. Under the layer properties and Themes in MapGuide, you can add a theme which will divide your layer based on a field.
Has there been any updates to this functionality? Can .lyr files be connected through Map Workspace in Civil 3D or is there a workaround to create a link to this type of data?
Many thanks.
Hello there,
Are there any recent advancements regarding this functionality? Is it now possible to establish a connection to .lyr files through Map Workspace in Civil 3D, or is there a workaround available to establish a link with this specific data format? Stay informed about the latest developments and explore potential solutions for integrating lyr files seamlessly into your workflow.
Best Regards
Devid Lucas
