Infrastructure Map Server General Discussion
New Member
hsmith
Message 1 of 2 (1,673 Views)
ESRI .lyr files
1673 Views, 1 Replies
09-29-2010 02:56 PM
Does Autodesk MapGuide support .lyr (layer) files?  If not, are there plans on adding the ability to see these services?
Active Contributor
amy7891
Message 2 of 2 (1,627 Views)
Re: ESRI .lyr files
11-02-2010 04:28 PM in reply to: hsmith
.lyr is not currently supported but MapGuide can import .shp, however this is not so useful for adding features with complex symbology. Under the layer properties and Themes in MapGuide, you can add a theme which will divide your layer based on a field.
