Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
error with extension join with oracle database
0 REPLIES 0
Message 1 of 1
189 Views, 0 Replies
we are trying to extend the map database with oracle using feature join. The join is on the string type column on map and char(20) on Oracle table.
There is no error in join, but after selection of joined extension in the " layer " edit wizard, error(you're about to change to an incompatible data resource) is raised as shown in attachment and the map contents in the viewer are vanished.
any help in this regard is greatly appreciated
0 REPLIES 0
