Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Error while importing DWG using Autodesk Infrastructure Studio
2 REPLIES 2
431 Views, 2 Replies
importing the provided example dwg files with Autodesk Infrastructure Studio 2014 worked fine.
Now I want to import a file provided by our customer with a lot of layers and then the Studio crashed.
Windows error log contains a message like this:
System.AccessViolationException
Stapel:
   bei <Module>.MdfModel.SimpleSymbolDefinition.GetPointUsage(MdfModel.SimpleSymbolDefinition*)
   bei Autodesk.MapGuide.Studio.Load.DwgLoadProcedure.BlocksToSymbols(System.String, AcDbDatabase*, Autodesk.MapGuide.Studio.Site.PackageWriter, Autodesk.MapGuide.Studio.Site.SiteConnection)
   bei Autodesk.MapGuide.Studio.Load.DwgLoadProcedure.WriteSymbolsOnly(Autodesk.MapGuide.Studio.Site.PackageWriter, Autodesk.MapGuide.Studio.Site.SiteConnection)
   bei Autodesk.MapGuide.Studio.Load.DwgLoadProcedure.Execute(System.String, Autodesk.MapGuide.Studio.Site.SiteConnection, Boolean)
   bei Autodesk.MapGuide.Studio.Load.LoadProcedure.Execute(Autodesk.MapGuide.Studio.Site.SiteConnection, Boolean)
   bei Autodesk.MapGuide.Studio.UI.LoadProcedureEditors.CustomEditorBase.Execute()
   bei Autodesk.MapGuide.Studio.Dwg.UI.LoadProcedureEditors.Dwg.Execute()
   bei Autodesk.MapGuide.Studio.UI.LoadProcedureEditors.LoadProcedureEditor.buttonLoadData_Click(System.Object, System.EventArgs)
   bei System.Windows.Forms.Control.OnClick(System.EventArgs)
   bei System.Windows.Forms.Button.OnClick(System.EventArgs)
   bei System.Windows.Forms.Button.WndProc(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.Control+ControlNativeWindow.OnMessage(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.Control+ControlNativeWindow.WndProc(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.NativeWindow.Callback(IntPtr, Int32, IntPtr, IntPtr)
   bei System.Windows.Forms.UnsafeNativeMethods.SendMessage(System.Runtime.InteropServices.HandleRef, Int32, IntPtr, IntPtr)
   bei System.Windows.Forms.Control.SendMessage(Int32, IntPtr, IntPtr)
   bei System.Windows.Forms.Control.ReflectMessageInternal(IntPtr, System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.Control.WmCommand(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.Control.WndProc(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.ScrollableControl.WndProc(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.UnsafeNativeMethods.CallWindowProc(IntPtr, IntPtr, Int32, IntPtr, IntPtr)
   bei System.Windows.Forms.NativeWindow.DefWndProc(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.Control.DefWndProc(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.Control.WmMouseUp(System.Windows.Forms.Message ByRef, System.Windows.Forms.MouseButtons, Int32)
   bei System.Windows.Forms.ButtonBase.WndProc(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG ByRef)
   bei System.Windows.Forms.Application+ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr, Int32, Int32)
   bei System.Windows.Forms.Application+ThreadContext.RunMessageLoopInner(Int32, System.Windows.Forms.ApplicationContext)
   bei System.Windows.Forms.Application+ThreadContext.RunMessageLoop(Int32, System.Windows.Forms.ApplicationContext)
   bei System.Windows.Forms.Application.Run(System.Windows.Forms.Form)
   bei Autodesk.MapGuide.Studio.Main.Splash.Main(System.String[])
Does anybody know what causes this problem and what I could do?
Alex.
2 REPLIES 2
Any ideas?
gluckett
If your DWG has Object Data or Link Templates you are going to need the HOTFIX for AIMS
http://knowledge.autodesk.com/support/infrastructure-map-server/downloads/caas/downloads/content/aut...
