Infrastructure Map Server General Discussion
New Member
akruth
Message 1 of 3 (173 Views)
Error while importing DWG using Autodesk Infrastructure Studio
173 Views, 2 Replies
02-10-2014 02:25 AM
importing the provided example dwg files with Autodesk Infrastructure Studio 2014 worked fine.
Now I want to import a file provided by our customer with a lot of layers and then the Studio crashed.
Windows error log contains a message like this:
System.AccessViolationException
Stapel:
   bei <Module>.MdfModel.SimpleSymbolDefinition.GetPointUsage(MdfModel.SimpleSymbolDefinition*)
   bei Autodesk.MapGuide.Studio.Load.DwgLoadProcedure.BlocksToSymbols(System.String, AcDbDatabase*, Autodesk.MapGuide.Studio.Site.PackageWriter, Autodesk.MapGuide.Studio.Site.SiteConnection)
   bei Autodesk.MapGuide.Studio.Load.DwgLoadProcedure.WriteSymbolsOnly(Autodesk.MapGuide.Studio.Site.PackageWriter, Autodesk.MapGuide.Studio.Site.SiteConnection)
   bei Autodesk.MapGuide.Studio.Load.DwgLoadProcedure.Execute(System.String, Autodesk.MapGuide.Studio.Site.SiteConnection, Boolean)
   bei Autodesk.MapGuide.Studio.Load.LoadProcedure.Execute(Autodesk.MapGuide.Studio.Site.SiteConnection, Boolean)
   bei Autodesk.MapGuide.Studio.UI.LoadProcedureEditors.CustomEditorBase.Execute()
   bei Autodesk.MapGuide.Studio.Dwg.UI.LoadProcedureEditors.Dwg.Execute()
   bei Autodesk.MapGuide.Studio.UI.LoadProcedureEditors.LoadProcedureEditor.buttonLoadData_Click(System.Object, System.EventArgs)
   bei System.Windows.Forms.Control.OnClick(System.EventArgs)
   bei System.Windows.Forms.Button.OnClick(System.EventArgs)
   bei System.Windows.Forms.Button.WndProc(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.Control+ControlNativeWindow.OnMessage(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.Control+ControlNativeWindow.WndProc(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.NativeWindow.Callback(IntPtr, Int32, IntPtr, IntPtr)
   bei System.Windows.Forms.UnsafeNativeMethods.SendMessage(System.Runtime.InteropServices.HandleRef, Int32, IntPtr, IntPtr)
   bei System.Windows.Forms.Control.SendMessage(Int32, IntPtr, IntPtr)
   bei System.Windows.Forms.Control.ReflectMessageInternal(IntPtr, System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.Control.WmCommand(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.Control.WndProc(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.ScrollableControl.WndProc(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.UnsafeNativeMethods.CallWindowProc(IntPtr, IntPtr, Int32, IntPtr, IntPtr)
   bei System.Windows.Forms.NativeWindow.DefWndProc(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.Control.DefWndProc(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.Control.WmMouseUp(System.Windows.Forms.Message ByRef, System.Windows.Forms.MouseButtons, Int32)
   bei System.Windows.Forms.ButtonBase.WndProc(System.Windows.Forms.Message ByRef)
   bei System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG ByRef)
   bei System.Windows.Forms.Application+ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr, Int32, Int32)
   bei System.Windows.Forms.Application+ThreadContext.RunMessageLoopInner(Int32, System.Windows.Forms.ApplicationContext)
   bei System.Windows.Forms.Application+ThreadContext.RunMessageLoop(Int32, System.Windows.Forms.ApplicationContext)
   bei System.Windows.Forms.Application.Run(System.Windows.Forms.Form)
   bei Autodesk.MapGuide.Studio.Main.Splash.Main(System.String[])
Does anybody know what causes this problem and what I could do?
Alex.
New Member
akruth
Message 2 of 3 (139 Views)
Re: Error while importing DWG using Autodesk Infrastructure Studio
02-17-2014 06:37 AM in reply to: akruth
Any ideas?
Valued Mentor
gluckett
Message 3 of 3 (94 Views)
04-10-2014 06:11 AM in reply to: akruth
If your DWG has Object Data or Link Templates you are going to need the HOTFIX for AIMS
http://knowledge.autodesk.com/support/infrastructure-map-server/downloads/caas/downloads/content/aut...
