Infrastructure Map Server Developer
rush.sheetal
Message 1 of 7 (1,817 Views)
Error when using "OSGeo.MapGuide" in C# file
1817 Views, 6 Replies
02-20-2007 01:07 AM
iam getting error when i tried to compile
my code behind file (C#) file
that
"OSGeo.MapGuide" namespace not found
but when i import namespace in asp.net page
using import "OSGeo.MapGuide"
no error comes n page run successfully
why this is so?
if i want to use "OSGeo.MapGuide in my cs file
why iam getting error....
i copied both dll mapguidedotnetapi.dll n maguidenammaged ...dll
to my application bin directory...
sheetal
Distinguished Contributor
jumpinjackie
Message 2 of 7 (1,817 Views)
Re: Error when using "OSGeo.MapGuide" in C# file
02-22-2007 03:53 PM in reply to: rush.sheetal
There's extra unmanaged dependencies in OSGeo.MapGuide.
Try copying every dll in the bin directory of the mapviewernet folder
Cheers,
Jackie
http://themapguyde.blogspot.com
http://au.linkedin.com/in/jackieng
rush.sheetal
Message 3 of 7 (1,817 Views)
02-24-2007 12:28 AM in reply to: rush.sheetal
I copied all file ...
stiil error comes in cs file..
New Member
vibha
Message 4 of 7 (1,817 Views)
06-01-2007 10:15 PM in reply to: rush.sheetal
hi,
i am using mapguide, but i am getting getting error saying missing directive. OSGeo.MapGuide. even though i have imported that namespace in aspx page.
Member
velan
Message 5 of 7 (1,817 Views)
07-01-2007 03:30 AM in reply to: rush.sheetal
Probably the AcMapApiMgd.dll is missing in reference..
Valued Contributor
raghulan
Message 6 of 7 (1,517 Views)
09-25-2012 09:12 PM in reply to: velan
Hello just incase someone needs the info..
that dll that contains the OSGeo.MapGuide;
Autodesk.Map.Platform.Core.dll
Cheers
Raghulan Gowthaman Cert IV TAA, B.E,.
Senior Technical Consultant | Developer - R&D
A2K Technologies Sydney
Web : www.a2ktechnologies.com.au
www.civil3dforum.com | www.e4forums.com
www.zcodia.com.au
www.raghulangowthaman.com
Board Manager
Daniel.Du
Message 7 of 7 (1,327 Views)
10-31-2012 10:27 PM in reply to: raghulan
Autodesk.Map.Platform.Core.dll and AcMapApiMgd.dll are part of Map 3D, not MapServer(AIMS or MapGuide).
You probably forget to convert your virtual directory to web application in IIS.
Daniel Du
Developer Technical Services
Autodesk Developer Network
