Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Error when using "OSGeo.MapGuide" in C# file
6 REPLIES 6
2418 Views, 6 Replies
iam getting error when i tried to compile
my code behind file (C#) file
that
"OSGeo.MapGuide" namespace not found
but when i import namespace in asp.net page
using import "OSGeo.MapGuide"
no error comes n page run successfully
why this is so?
if i want to use "OSGeo.MapGuide in my cs file
why iam getting error....
i copied both dll mapguidedotnetapi.dll n maguidenammaged ...dll
to my application bin directory...
sheetal
6 REPLIES 6
jumpinjackie
There's extra unmanaged dependencies in OSGeo.MapGuide.
Try copying every dll in the bin directory of the mapviewernet folder
Cheers,
Jackie
http://themapguyde.blogspot.com
http://au.linkedin.com/in/jackieng
I copied all file ...
stiil error comes in cs file..
hi,
i am using mapguide, but i am getting getting error saying missing directive. OSGeo.MapGuide. even though i have imported that namespace in aspx page.
Probably the AcMapApiMgd.dll is missing in reference..
raghulan
Hello just incase someone needs the info..
that dll that contains the OSGeo.MapGuide;
Autodesk.Map.Platform.Core.dll
Cheers
Raghulan Gowthaman Cert IV TAA, B.E,.
Senior Technical Consultant | Developer - R&D
A2K Technologies Sydney
Web : www.a2ktechnologies.com.au
www.civil3dforum.com | www.e4forums.com
www.zcodia.com.au
www.raghulangowthaman.com
Daniel.Du
in reply to: raghulan
Autodesk.Map.Platform.Core.dll and AcMapApiMgd.dll are part of Map 3D, not MapServer(AIMS or MapGuide).
You probably forget to convert your virtual directory to web application in IIS.
Daniel Du
Developer Technical Services
Autodesk Developer Network
