Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Error when using findparceltask
4 REPLIES 4
329 Views, 4 Replies
I have switched around the findparceltask.aspx and findparcel pages to search for data in my map. When I input an item that is not a valid value and search I get the typical message "0 matches found." However, when I search for a valid item I get another error message: "The specified object was not found.The specified object was not found. Exception occurred in method GetItem at line 115 in file c:\build_tux_area\mgdev\common\service\data\NamedCollection.cpp"
Does anybody know what would cause this error message?
4 REPLIES 4
I now also get this error message:
"Resource was not found: Session:6086b872-0000-1000-8000-0013200eb35c_en//Map.MapResource was not found: Session:6086b872-0000-1000-8000-0013200eb35c_en//Map.Map Exception occurred in method MgResourceDefinitionManager.GetDocument at line 483 in file c:\build_tux_area\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp "
Any help please?
> line 483 in file
> Any help please?
Sounds like your session has expired. Reload the map and try again.
James Card
I have been working on Mapguide for a few weeks now and have not been having problems displaying my initial frameset with initial map. All of sudden this morning I start getting this message
I haven't seen a fix for this error posted yet. Does anybody know any more about it?
In case you may not have found the solution, I fixed my issue by deleting my weblayout (in studio) and recreating it. Apparently something got corrupt with the weblayout and it was not able to find something that the weblayout was referencing.
