Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Error message
2 REPLIES 2
231 Views, 2 Replies
Error message
I've been getting an error message (see attached image) and I'm not sure why. I just started using Mapguide studio 2009 20 minutes ago and the error happens when I'm trying to load .dwg. Thanks for the help.
2 REPLIES 2
and by the way, there is no error when using the sample data, just my data.
dswilson
It's not clear what is wrong here. The error message says there is a problem trying to preview which normally occurs when previewing a feature source (Data connection), a layer, a map or a layout.
Can you provide more detailed steps about what you are doing and at what point does this error occur?
Dave
